[petsc-dev] [petsc-maint] valgrind detected on /usr/local/include and enabled but header files from this dir are not added to build path
Tue Oct 29 16:11:33 CDT 2013
On Tue, 29 Oct 2013, Matthew Knepley wrote:
> > Matt is the one with vision about BuildSystem dependencies so I'll leave
> > it to him to comment.
> I see fooling with dependencies as a good thing in general to simplify
> things, but having not
> much to do with what Jed wants. We can easily buffer till kingdom come.
> What needs to be done is to overload write() for the logger, so that if no
> file is open it buffers,
> and then when a file is set, the contents get dumped in.
The issue is: if there is an error in configure thats relavent [for
which we want the user to send us configure.log from the predetermined
location] - but this error happens before the 'file is set' i.e before
PETSC_ARCH is determined.
Satish
