[petsc-dev] [petsc-maint] valgrind detected on /usr/local/include and enabled but header files from this dir are not added to build path
Tue Oct 29 14:07:31 CDT 2013
  It is not worthy any additional logic in the already messing configure process to save a few downloads.
   Barry
On Oct 29, 2013, at 1:59 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 29 Oct 2013, Jed Brown wrote:
>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>   Or simpler just have the —with-clean nuke external packages; makes
>>>   life easy.  By "store the tarballs in a common place” and SHA1 crap
>>>   you are making the system more complicated to understand and
>>>   maintain.
>> People will complain when they have to download the same tarball many
>> times.  But I don't especially care as long as the builds are done
>> inside $PETSC_ARCH instead of in a common place.  (This is also useful
>> when building multiple configurations of PETSc in parallel.)
> There is also the issue with git repos to deal with. [presumably the
> above logic would be slightly different than the tarballs]
> We [Jed and I ] also discussed having git repos and corresponding
> tarballs match - and caching tarballs locally for unreliable external
> sites. And then using SHA as a way of versioning to eliminate most
> cases where with-clean would be needed.
> Just a note: all these issues are primarily with git users - not
> petsc-release/tarball users.
> Satish
