[petsc-dev] [petsc-maint] valgrind detected on	/usr/local/include and enabled but header files from this dir	are not added to build path
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Oct 29 13:51:57 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Or simpler just have the —with-clean nuke external packages; makes
>    life easy.  By "store the tarballs in a common place” and SHA1 crap
>    you are making the system more complicated to understand and
>    maintain.
People will complain when they have to download the same tarball many
times.  But I don't especially care as long as the builds are done
inside $PETSC_ARCH instead of in a common place.  (This is also useful
when building multiple configurations of PETSc in parallel.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/dd42a127/attachment.sig>
