[petsc-dev] PetscCitations: software or underlying math
    Matthew Knepley
    knepley at gmail.com
    Thu Oct 24 13:01:13 CDT 2013
On Thu, Oct 24, 2013 at 11:31 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > I think we can differentiate between mathematical background and
> analysis,
> > e.g.
> >   Proving that GMRES converges with these matrices, etc.
> > and showing exactly how to structure an algorithm:
> >   Saad and Schultz, 96
> *86*, but what about GCR?  After all, GMRES is an incremental
I'm getting too old.
>  modification of GCR.  It also contains mispredictions like:
I would argue that Saad's implementation suggestions (like incremental QR)
are
much better than the GCR and justify an independent citation.
>   "In practical implementation it is usually more suitable to replace
>   the Gram-Schmidt algorithm of step 2 by the modified Gram-Schmidt
>   algorithm"
> If someone uses LGMRES, would we produce a citation only to Baker et al,
Only to Baker. This should be easy since SS would be associated with GMRES.
> or also to Saad & Schultz?  What about the BiCG family, containing many
> more variants that are slight variations on existing methods?  Or
We need to build in support for selection with options I think.
> identical methods that were published twice under different names?
Cite both.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131024/2870c912/attachment.html>
