[petsc-dev] PetscCitations: software or underlying math
Jed Brown
jedbrown at mcs.anl.gov
Thu Oct 24 11:31:25 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> I think we can differentiate between mathematical background and analysis,
> e.g.
> Proving that GMRES converges with these matrices, etc.
> and showing exactly how to structure an algorithm:
> Saad and Schultz, 96
*86*, but what about GCR? After all, GMRES is an incremental
modification of GCR. It also contains mispredictions like:
"In practical implementation it is usually more suitable to replace
the Gram-Schmidt algorithm of step 2 by the modified Gram-Schmidt
algorithm"
If someone uses LGMRES, would we produce a citation only to Baker et al,
or also to Saad & Schultz? What about the BiCG family, containing many
more variants that are slight variations on existing methods? Or
identical methods that were published twice under different names?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131024/b6242116/attachment.sig>
