[petsc-dev] [Bitbucket] Pull request #109: Added at test, simplified version of ex11, convergence test. Uses differencing to produce matrix in stand alone code, fixed SNES to support this. (petsc/petsc)
    Matthew Knepley
    knepley at gmail.com
    Thu Oct 24 11:03:27 CDT 2013
On Thu, Oct 24, 2013 at 10:31 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> @madams This branch is totally unreviewable in its current form, and
> it cannot be bisected because many of the intermediate states are
> broken.  I understand making haphazard/checkpoint commits while
> developing, but to maintain reviewability and quality in the long term,
> it's important to organize the commits so that they can be understood in
> sequence.  Commit messages like "...", "temp version", and "cleaning up"
> force the reviewer to read the commit in its entirety to have any idea
> what it is supposed to accomplish.  This makes it difficult to keep
> track of what is happening, which discourages people from following
> development, avoiding duplicate/conflicting work, etc.
> We have to support everything that goes into PETSc, but if we can't
> follow development, we give outdated advice and end up unable to answer
> questions.
> Most people working on PETSc are organizing their commits to be
> reviewable these days.  We can go to the commit and branch lists (in the
> web interface or with Git locally) and the first line of the commit
> message gives a good summary of what the commit is accomplishing, the
> body of the commit message explains why it is important/who may be
> impacted by the change, and the commit itself accomplishes something
> that the viewer can check.  This allows other developers to quickly get
> the gist of what is in a branch, what may be interesting to look at in
> more detail, etc.
> Commit topology and messages are key means by which developers
> communicate with each other.  It really doesn't take much effort once
> you get in the habit of organizing commits as a means of communication
> rather than as a log with arbitrary checkpoints.
> Any other means of communication, such as pull request summaries or
> mailing list threads, are secondary sources, inherently more error-prone
> and higher effort to evaluate, and provide less structure for automated
> diagnostics/summaries.
> https://bitbucket.org/petsc/petsc/wiki/writing-commit-messages
> Git provides good tools for reordering/squashing/amending commits, so
> it's possible to develop in clutter and then organize when it's time to
> communicate to other people.
> This PR is blocked on some of Matt's long-running branches.  @knepley
> When will 'knepley/feature-dmda-section' and
> 'knepley/feature-plex-refine-3d' be ready to merge?
knepley/feature-plex-refine-3d this could really merge tomorrow if we
needed it, and
I would do another branch to add the hex support.
It should not be blocked on knepley/feature-dmda-section, which is going to
take some
time.
   Matt
> Mark Adams <pullrequests-reply at bitbucket.org> writes:
> > --- you can reply above this line ---
> > A new pull request has been opened by Mark Adams.
> > madams/sr-driver2 has changes to be pulled into master.
> https://bitbucket.org/petsc/petsc/pull-request/109/added-at-test-simplified-version-of-ex11
> > Title: Added at test, simplified version of ex11, convergence test.
> support this.
> > Changes to be pulled:
> > c1fa6a8934f2 by Mark Adams: "cleanup jed's cherry picked version"
> > e7b0c4510d02 by Jed Brown: "Merge branch 'knepley/fix-plex-ghost-cells'
> into jed/sr-driver
> > DMLabelFilter is…"
> > c56f055af68b by Mark Adams: "finished up adding serial DMPlex test with
> a convergance test on a 5-point Lapla…"
> > 8fdc87fb42d2 by Mark Adams: "cleaning up"
> > 0fb202fbc65d by Mark Adams: "cleaning up
> > Conflicts:
> >       src/ts/examples/tutorials/makefile"
> > ... and 112 more.
> > Unsubscribe from pull request emails for this repository.
> https://bitbucket.org/petsc/petsc/pull-request/109/unsubscribe/jedbrown/bc8a9c9283892888c102096c5dadc4a6a692a4fe/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131024/e18da8de/attachment.html>
