[petsc-dev] Problem with SLEPC Eigenvalue Problem Solver
    Ricardo Marquez
    ricardo.marquez.88 at gmail.com
    Tue Oct 22 07:39:16 CDT 2013
Hi, I'm trying to solve a vibration generalized eigenvalue problem like
this:
|  K    C |  =  lambda* | M  0 |
| C^t   0 |                    | 0  0 |
I have try a lot of convinations eigensolvers, KSP and PC, but I can't make
that it works.
I use the ST shift-and-invert to get the firsts 5 eigenvalues.
If I use PC or ST_PC = LU or CHOLESKY, I get the zero pivot message error.
If I use PC and ST_PC = NONE, the 5 eigenvalues that find the solver are
exactly the same and equal to the shift value.
If I use PC = jacobi or bjacobi, the eigenvalues get a very big value.
Does anyone knows how this kind of problem solve?
thanks!
Ricardo Márquez
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131022/e1ef902b/attachment.html>
