[petsc-dev] moab in nightlybuild has erors..
    Satish Balay
    balay at mcs.anl.gov
    Sun Oct 20 20:27:01 CDT 2013
On Sun, 20 Oct 2013, Vijay S. Mahadevan wrote:
> Satish,
> Iulian just fixed the problems on MOAB master and so further builds
> should run cleanly.
great!
> Is there a way to subscribe to buildbot failures
> relating only to MOAB in PETSc ? If that is the case, you can add
> moab-dev at mcs.anl.gov to that list.
petsc builds are not with buildbot. Currently we look at the logs
manually to determine the issues.
Satish
> Thanks,
> Vijay
> On Sun, Oct 20, 2013 at 10:17 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > from ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/10/20/configure_next_arch-freebsd-cxx-pkgs-opt_wii.log
> >                     Downloading MOAB
> >                       Downloading http://ftp.mcs.anl.gov/pub/fathom/moab-nightly.tar.gz to /usr/home/balay/petsc.clone-2/externalpackages/_d_moab-nightly.tar.gz
> > libtool: compile:  /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHAVE_IEEEFP_H -DUSE_MPI -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I./.. -I./../parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O -fPIC -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -MT NCHelperMPAS.lo -MD -MP -MF .deps/NCHelperMPAS.Tpo -c NCHelperMPAS.cpp  -fPIC -DPIC -o .libs/NCHelperMPAS.o
> > *** [NCHelperMPAS.lo] Error code 1
> > Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre/src/io.
> > *** [all-recursive] Error code 1
> > Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre/src.
> > *** [all] Error code 1
> > Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre.
> > Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre.ReadTetGen.cpp: In member function 'moab::ErrorCode moab::ReadTetGen::read_elem_file(moab::EntityType, std::istream&, const std::vector<long unsigned int, std::allocator<long unsigned int> >&, moab::Range&)':
> > ReadTetGen.cpp:371: warning: 'have_group_id' may be used uninitialized in this function
> > ReadTetGen.cpp:371: warning: 'node_per_elem' may be used uninitialized in this function
> > NCHelperMPAS.cpp: In member function 'virtual moab::ErrorCode moab::NCHelperMPAS::create_mesh(moab::Range&)':
> > NCHelperMPAS.cpp:312: error: 'MBZoltan' was not declared in this scope
> > NCHelperMPAS.cpp:312: error: 'mbZTool' was not declared in this scope
> > NCHelperMPAS.cpp:312: error: expected type-specifier before 'MBZoltan'
> > NCHelperMPAS.cpp:312: error: expected `;' before 'MBZoltan'
> > NCHelperMPAS.cpp:316: error: 'nc_get_vara_double_all' was not declared in this scope
> > NCHelperMPAS.cpp:317: error: 'nc_get_vara_double_all' was not declared in this scope
> > NCHelperMPAS.cpp:318: error: 'nc_get_vara_double_all' was not declared in this scope
