[petsc-dev] moab in nightlybuild has erors..
    Vijay S. Mahadevan
    vijay.m at gmail.com
    Sun Oct 20 11:55:18 CDT 2013
Satish,
Iulian just fixed the problems on MOAB master and so further builds
should run cleanly. Is there a way to subscribe to buildbot failures
relating only to MOAB in PETSc ? If that is the case, you can add
moab-dev at mcs.anl.gov to that list.
Vijay
On Sun, Oct 20, 2013 at 10:17 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> from ftp://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/10/20/configure_next_arch-freebsd-cxx-pkgs-opt_wii.log
>                     Downloading MOAB
>                       Downloading http://ftp.mcs.anl.gov/pub/fathom/moab-nightly.tar.gz to /usr/home/balay/petsc.clone-2/externalpackages/_d_moab-nightly.tar.gz
> libtool: compile:  /usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/bin/mpicxx -DHAVE_CONFIG_H -I. -I../.. -I../../src/moab -I../../src/parallel -I../../src -I/usr/home/balay/petsc.clone-2/arch-freebsd-cxx-pkgs-opt/include -DTEMPLATE_SPECIALIZATION -DTEMPLATE_FUNC_SPECIALIZATION -DHAVE_VSNPRINTF -D_FILE_OFFSET_BITS=64 -DHAVE_IEEEFP_H -DUSE_MPI -DNETCDF_FILE -DIS_BUILDING_MB -I.. -I./.. -I./../parallel -DUNORDERED_MAP_NS=std::tr1 -DHAVE_UNORDERED_MAP=tr1/unordered_map -DHAVE_UNORDERED_SET=tr1/unordered_set -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O -fPIC -Wall -pipe -pedantic -Wno-long-long -Wextra -Wcast-align -Wpointer-arith -Wformat -Wformat-security -Wshadow -Wunused-parameter -MT NCHelperMPAS.lo -MD -MP -MF .deps/NCHelperMPAS.Tpo -c NCHelperMPAS.cpp  -fPIC -DPIC -o .libs/NCHelperMPAS.o
> *** [NCHelperMPAS.lo] Error code 1
> Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre/src/io.
> *** [all-recursive] Error code 1
> Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre/src.
> *** [all] Error code 1
> Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre.
> Stop in /usr/home/balay/petsc.clone-2/externalpackages/moab-4.7.0pre.ReadTetGen.cpp: In member function 'moab::ErrorCode moab::ReadTetGen::read_elem_file(moab::EntityType, std::istream&, const std::vector<long unsigned int, std::allocator<long unsigned int> >&, moab::Range&)':
> ReadTetGen.cpp:371: warning: 'have_group_id' may be used uninitialized in this function
> ReadTetGen.cpp:371: warning: 'node_per_elem' may be used uninitialized in this function
> NCHelperMPAS.cpp: In member function 'virtual moab::ErrorCode moab::NCHelperMPAS::create_mesh(moab::Range&)':
> NCHelperMPAS.cpp:312: error: 'MBZoltan' was not declared in this scope
> NCHelperMPAS.cpp:312: error: 'mbZTool' was not declared in this scope
> NCHelperMPAS.cpp:312: error: expected type-specifier before 'MBZoltan'
> NCHelperMPAS.cpp:312: error: expected `;' before 'MBZoltan'
> NCHelperMPAS.cpp:316: error: 'nc_get_vara_double_all' was not declared in this scope
> NCHelperMPAS.cpp:317: error: 'nc_get_vara_double_all' was not declared in this scope
> NCHelperMPAS.cpp:318: error: 'nc_get_vara_double_all' was not declared in this scope
