[petsc-dev] nightly build errros with next
    Matthew Knepley
    knepley at gmail.com
    Tue Oct 15 13:51:57 CDT 2013
On Tue, Oct 15, 2013 at 11:30 AM, Satish Balay <balay at mcs.anl.gov> wrote:
Fixed.
   Matt
>From build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log
> [ 72%] Building CXX object
> CMakeFiles/petsc.dir/src/dm/impls/composite/f90-custom/zfddaf90.c.o
> /usr/home/balay/petsc.clone-3/src/dm/dt/interface/dtfe.c: In function
> 'PetscErrorCode PetscFEGetTabulation(_p_PetscFE*, PetscInt, const
> PetscReal*, PetscReal**, PetscReal**, PetscReal**)':
> /usr/home/balay/petsc.clone-3/src/dm/dt/interface/dtfe.c:2264: warning:
> unused variable 'n'
> unused variable 'info'
> [ 93%] Building CXX object
> CMakeFiles/petsc.dir/src/snes/interface/snesut.c.o
> /usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c: In function
> 'PetscErrorCode SNESSetWorkVecs(_p_SNES*, PetscInt)':
> /usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c:560: error:
> 'DMGetGlobalVector' was not declared in this scope
> /usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c:562: error:
> 'DMRestoreGlobalVector' was not declared in this scope
> *** [CMakeFiles/petsc.dir/src/snes/interface/snesut.c.o] Error code 1
> 1 error
> From build_next_arch-freebsd-cxx-pkgs-opt_wii.log
> [ 48%] Building CXX object
> CMakeFiles/petsc.dir/src/mat/impls/aij/seq/mattransposematmult.c.o
> /usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c: In function
> 'PetscErrorCode MatSOR_SeqAIJ_Inode(_p_Mat*, _p_Vec*, PetscReal,
> MatSORType, PetscReal, PetscInt, PetscInt, _p_Vec*)':
> /usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2761: warning:
> 'v5' may be used uninitialized in this function
> 'v4' may be used uninitialized in this function
> [ 49%] Building CXX object
> CMakeFiles/petsc.dir/src/mat/impls/aij/seq/bas/basfactor.c.o
> 'v3' may be used uninitialized in this function
> 'v2' may be used uninitialized in this function
> /usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2758: warning:
> 'sum5' may be used uninitialized in this function
> 'sum4' may be used uninitialized in this function
> 'sum3' may be used uninitialized in this function
> 'sum2' may be used uninitialized in this function
> 'v1' may be used uninitialized in this function
> 'sum1' may be used uninitialized in this function
> [ 69%] Building CXX object
> CMakeFiles/petsc.dir/src/dm/impls/plex/plexreorder.c.o
> /usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexreorder.c: In function
> 'PetscErrorCode DMPlexPermute(_p_DM*, _p_IS*, _p_DM**)':
> /usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexreorder.c:179:
> warning: 'labelNew' may be used uninitialized in this function
> [ 71%] Building CXX object
> /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c: In function
> 'PetscErrorCode PetscFEIntegrateBdResidual_Basic(_p_PetscFE*, PetscInt,
> PetscInt, _p_PetscFE**, PetscInt, PetscCellGeometry, const PetscScalar*,
> PetscInt, _p_PetscFE**, const PetscScalar*, void (*)(const PetscScalar*,
> const PetscScalar*, const PetscScalar*, const PetscScalar*, const
> PetscReal*, const PetscReal*, PetscScalar*), void (*)(const PetscScalar*,
> PetscReal*, const PetscReal*, PetscScalar*), PetscScalar*)':
> /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2552: warning:
> 'gradA' may be used uninitialized in this function
> 'PetscErrorCode PetscFEIntegrateResidual_Basic(_p_PetscFE*, PetscInt,
> PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*,
> const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*),
> PetscScalar*)':
> /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2353: warning:
> CMakeFiles/petsc.dir/src/dm/impls/da/f90-custom/zdaindexf90.c.o
> 'PetscErrorCode PetscFEIntegrateJacobian_Basic(_p_PetscFE*, PetscInt,
> PetscInt, _p_PetscFE**, PetscInt, PetscInt, PetscCellGeometry, const
> PetscScalar*, PetscInt, _p_PetscFE**, const PetscScalar*, void (*)(const
> PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*,
> const PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const
> PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*,
> PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*, const
> PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), void
> (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const
> PetscScalar*, const PetscReal*, PetscScalar*), PetscScalar*)':
> /usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2762: warning:
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131015/3f6738a6/attachment.html>
