[petsc-dev] nightly build errros with next
    Satish Balay
    balay at mcs.anl.gov
    Tue Oct 15 11:30:38 CDT 2013
>From build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log
[ 72%] Building CXX object CMakeFiles/petsc.dir/src/dm/impls/composite/f90-custom/zfddaf90.c.o
/usr/home/balay/petsc.clone-3/src/dm/dt/interface/dtfe.c: In function 'PetscErrorCode PetscFEGetTabulation(_p_PetscFE*, PetscInt, const PetscReal*, PetscReal**, PetscReal**, PetscReal**)':
/usr/home/balay/petsc.clone-3/src/dm/dt/interface/dtfe.c:2264: warning: unused variable 'n'
/usr/home/balay/petsc.clone-3/src/dm/dt/interface/dtfe.c:2264: warning: unused variable 'info'
[ 93%] Building CXX object CMakeFiles/petsc.dir/src/snes/interface/snesut.c.o
/usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c: In function 'PetscErrorCode SNESSetWorkVecs(_p_SNES*, PetscInt)':
/usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c:560: error: 'DMGetGlobalVector' was not declared in this scope
/usr/home/balay/petsc.clone-3/src/snes/interface/snesut.c:562: error: 'DMRestoreGlobalVector' was not declared in this scope
*** [CMakeFiles/petsc.dir/src/snes/interface/snesut.c.o] Error code 1
1 error
>From build_next_arch-freebsd-cxx-pkgs-opt_wii.log
[ 48%] Building CXX object CMakeFiles/petsc.dir/src/mat/impls/aij/seq/mattransposematmult.c.o
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c: In function 'PetscErrorCode MatSOR_SeqAIJ_Inode(_p_Mat*, _p_Vec*, PetscReal, MatSORType, PetscReal, PetscInt, PetscInt, _p_Vec*)':
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2761: warning: 'v5' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2761: warning: 'v4' may be used uninitialized in this function
[ 49%] Building CXX object CMakeFiles/petsc.dir/src/mat/impls/aij/seq/bas/basfactor.c.o
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2761: warning: 'v3' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2761: warning: 'v2' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2758: warning: 'sum5' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2758: warning: 'sum4' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2758: warning: 'sum3' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2758: warning: 'sum2' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2761: warning: 'v1' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/mat/impls/aij/seq/inode.c:2758: warning: 'sum1' may be used uninitialized in this function
[ 69%] Building CXX object CMakeFiles/petsc.dir/src/dm/impls/plex/plexreorder.c.o
/usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexreorder.c: In function 'PetscErrorCode DMPlexPermute(_p_DM*, _p_IS*, _p_DM**)':
/usr/home/balay/petsc.clone-2/src/dm/impls/plex/plexreorder.c:179: warning: 'labelNew' may be used uninitialized in this function
[ 71%] Building CXX object CMakeFiles/petsc.dir/src/dm/impls/composite/f90-custom/zfddaf90.c.o
/usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c: In function 'PetscErrorCode PetscFEIntegrateBdResidual_Basic(_p_PetscFE*, PetscInt, PetscInt, _p_PetscFE**, PetscInt, PetscCellGeometry, const PetscScalar*, PetscInt, _p_PetscFE**, const PetscScalar*, void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, const PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, const PetscReal*, PetscScalar*), PetscScalar*)':
/usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2552: warning: 'gradA' may be used uninitialized in this function
/usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c: In function 'PetscErrorCode PetscFEIntegrateResidual_Basic(_p_PetscFE*, PetscInt, PetscInt, _p_PetscFE**, PetscInt, PetscCellGeometry, const PetscScalar*, PetscInt, _p_PetscFE**, const PetscScalar*, void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), PetscScalar*)':
/usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2353: warning: 'gradA' may be used uninitialized in this function
[ 71%] Building CXX object CMakeFiles/petsc.dir/src/dm/impls/da/f90-custom/zdaindexf90.c.o
/usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c: In function 'PetscErrorCode PetscFEIntegrateJacobian_Basic(_p_PetscFE*, PetscInt, PetscInt, _p_PetscFE**, PetscInt, PetscInt, PetscCellGeometry, const PetscScalar*, PetscInt, _p_PetscFE**, const PetscScalar*, void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), void (*)(const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscScalar*, const PetscReal*, PetscScalar*), PetscScalar*)':
/usr/home/balay/petsc.clone-2/src/dm/dt/interface/dtfe.c:2762: warning: 'gradA' may be used uninitialized in this function
Satish
