[petsc-dev] PETSc-3.4 PR open at	https://github.com/Homebrew/homebrew-science/pull/343
    Aron Ahmadia
    aron at ahmadia.net
    Sat Oct 12 10:10:35 CDT 2013
Hi All,
The PR has raised a few issues in what PETSc does when it performs a
prefix install.  In particular, PETSc generates the following files:
$PREFIX/include/makefile
$PREFIX/lib/modules/3.4.1
Neither of these have been properly namespaced.  I'd suggest changing these to:
$PREFIX/include/petsc/makefile
$PREFIX/lib/modules/petsc/3.4.1
I'm not sure about the latter, I really don't know how package
managers deal with local modules install, or if it's worth even
putting it in if the user is requesting a PREFIX install.
Another option would be to include the PETSc ARCH in the directory namespacing:
$PREFIX/include/petsc/linux-gnu/makefile
$PREFIX/lib/modules/petsc/linux-gnu/3.4.1
Thoughts?
-A
On Wed, Sep 18, 2013 at 6:34 PM, Aron Ahmadia <aron at ahmadia.net> wrote:
> Prof. Orban has generously contributed a PR to get PETSc-3.4 going on
> homebrew at the following link:
> It's currently set up to use dynamic libraries, a homebrew-installed Fortran
> and a homebrew-installed MPI, with an optional dependency on X11 (used if
> available).
> It would probably not be too much more work to make the Fortran dependency
> optional, or add any other packages that are frequently used with PETSc.
> Any thoughts from the developers?
> Cheers,
> Aron
