[petsc-dev] MatMult
Stefano Zampini s.zampini at cineca.it
Wed Oct 9 07:23:29 CDT 2013
Just an update: I ran with -info, and saw that the 186x6 matrix uses
compressed rows routines, whereas 171x21 does not.
2013/10/9 Stefano Zampini <s.zampini at cineca.it>
> I just noticed unexpected behaviour of MatMult_SeqBAIJ_3 in PCBDDC code
> (on branch stefano_zampini/pcbddc-baijfixes) with rectangular matrices
> having number of rows >> number of cols and number of cols =2*blocksize. I
> guess this problem will show up for other values of block sizes.
> When some rows of the matrix are empty, the corresponding entry in the
> resulting vector is not zero (as expected, mathematically speaking);
> instead, the values are not overwritten at all. Is it the expected
> behaviour?
> Attached are two matrices . The one with sizes 186x6 shows the problem on
> my laptop (ubuntu, gnu compilers,  --with-debugging, , CFLAGS -g -O0)
> I'm not familiar with PETSc low-level implementation of BAIJ, so I cannot
> dig anymore into the problem apart saying that:
> A) if "converted" to SeqAIJ with a call
> MatConvert(Mymat,MATSEQAIJ,MAT_REUSE_MATRIX,&Mymat)
> the output of MatMult is always correct.
> B) the problem disappear by increasing the number of columns (the matrix
> with sizes 171x21 does not show the problem).
> Hope you can reproduce the problem,
> Ph. D. Stefano Zampini
> CINECA
> SuperComputing Applications and Innovations Department - SCAI
> Via dei Tizii, 6 00185 Roma - ITALY
> Email: s.zampini at cineca.it
> SkypeID: stefano.zampini
> GoogleTalk: stefano.zampini at gmail.com
> Tel: +39 06.44486.707
CINECA
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131009/5571bf95/attachment.html>
