[petsc-dev] MatMult
Stefano Zampini
s.zampini at cineca.it
Wed Oct 9 05:01:21 CDT 2013
I just noticed unexpected behaviour of MatMult_SeqBAIJ_3 in PCBDDC code (on
branch stefano_zampini/pcbddc-baijfixes) with rectangular matrices having
number of rows >> number of cols and number of cols =2*blocksize. I guess
this problem will show up for other values of block sizes.
When some rows of the matrix are empty, the corresponding entry in the
resulting vector is not zero (as expected, mathematically speaking);
instead, the values are not overwritten at all. Is it the expected
behaviour?
Attached are two matrices . The one with sizes 186x6 shows the problem on
my laptop (ubuntu, gnu compilers, --with-debugging, , CFLAGS -g -O0)
I'm not familiar with PETSc low-level implementation of BAIJ, so I cannot
dig anymore into the problem apart saying that:
A) if "converted" to SeqAIJ with a call
MatConvert(Mymat,MATSEQAIJ,MAT_REUSE_MATRIX,&Mymat)
the output of MatMult is always correct.
B) the problem disappear by increasing the number of columns (the matrix
with sizes 171x21 does not show the problem).
Hope you can reproduce the problem,
Ph. D. Stefano Zampini
CINECA
SuperComputing Applications and Innovations Department - SCAI
Via dei Tizii, 6 00185 Roma - ITALY
Email: s.zampini at cineca.it
SkypeID: stefano.zampini
GoogleTalk: stefano.zampini at gmail.com
Tel: +39 06.44486.707
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131009/306095a1/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131009/306095a1/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131009/306095a1/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131009/306095a1/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131009/306095a1/attachment-0003.obj>
