[petsc-dev] Supporting --download-hdf5 in Cygwin?
    Richard Tran Mills
    rtm at eecs.utk.edu
    Mon Oct  7 11:50:16 CDT 2013
Matt,
I tried this and it works under 32-bit Cygwin.  It should also work under
64-bit Cygwin except that it hits an error when building the 'h5ls' target
(can overcome this by telling make to ignore errors or by making a small
patch to the relevant HDF5 code--this is a Cygwin64/HDF5 problem and has
nothing to do with BuildSystem).
Can we go ahead and get this change into 'master' ASAP?  I am not sure of
the proper workflow to use for such a small change as this.  I'd like
--download-hdf5 to be working before I leave for Germany in a few days to
do a short course there.
--Richard
On 10/4/13 5:45 PM, Matthew Knepley wrote:
> On Fri, Oct 4, 2013 at 4:42 PM, Richard Tran Mills <rtm at eecs.utk.edu
> <mailto:rtm at eecs.utk.edu>> wrote:
>     Hi Satish,
>     I got this message attempting to use the Gnu compilers; that's all
>     that I've got on this system.  Should I send the configure.log to
>     petsc-maint?
> Want to add
>   self.downloadonWindows   = 1
> to __init__ of config/BuildSystem/config/packages/hdf5.py and see if it
> work?
>   Thanks,
>     Matt
>     --Richard
>     On 10/4/13 4:34 PM, Satish Balay wrote:
>         On Fri, 4 Oct 2013, Richard Tran Mills wrote:
>             Hi Folks,
>             If I tell configure.py '--download-hdf5=1', I get a message
>             that "External
>             package hdf5 does not support --download-hdf5 on Microsoft
>             Windows".  However,
>             I just built HDF5 1.8.11 from source under 64-bit Cygwin
>             and, except for one
>             problem with building the 'h5ls' utility, it appears that
>             this ought to work.
>             Can we support this? And what is the procedure for changing
>             package
>             configuration info in BuildSystem these days?  These files
>             show up in the
>             'petsc' repo but there appears to be a 'buildsystem' repo on
>             BitBucket as
>             well; not sure what the relationship is between them.
>         When you say 'Supporting --download-hdf5 in Cygwin' and refer to
>         64-bit - you
>         mean MS compilers or cygwin gcc/gfortran?
>         The error message should come up only with MS compilers.
>         Presumably --download-hdf5 should work with gnu compilers - if
>         it doesn't - it
>         probably needs some tweaking.
>         Wrt repo - we now have a single git repo
>         bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
>         where all petsc/buildsystem changes should go to.
>         Satish
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131007/f4ec4040/attachment.html>
