[petsc-dev] Supporting --download-hdf5 in Cygwin?
    Matthew Knepley
    knepley at gmail.com
    Fri Oct  4 16:45:16 CDT 2013
On Fri, Oct 4, 2013 at 4:42 PM, Richard Tran Mills <rtm at eecs.utk.edu> wrote:
> Hi Satish,
> I got this message attempting to use the Gnu compilers; that's all that
> I've got on this system.  Should I send the configure.log to petsc-maint?
Want to add
  self.downloadonWindows   = 1
to __init__ of config/BuildSystem/config/packages/hdf5.py and see if it
work?
    Matt
> --Richard
> On 10/4/13 4:34 PM, Satish Balay wrote:
>> On Fri, 4 Oct 2013, Richard Tran Mills wrote:
>>  Hi Folks,
>>> If I tell configure.py '--download-hdf5=1', I get a message that
>>> "External
>>> package hdf5 does not support --download-hdf5 on Microsoft Windows".
>>>  However,
>>> I just built HDF5 1.8.11 from source under 64-bit Cygwin and, except for
>>> one
>>> problem with building the 'h5ls' utility, it appears that this ought to
>>> work.
>>> Can we support this? And what is the procedure for changing package
>>> configuration info in BuildSystem these days?  These files show up in the
>>> 'petsc' repo but there appears to be a 'buildsystem' repo on BitBucket as
>>> well; not sure what the relationship is between them.
>> When you say 'Supporting --download-hdf5 in Cygwin' and refer to 64-bit -
>> you
>> mean MS compilers or cygwin gcc/gfortran?
>> The error message should come up only with MS compilers.
>> Presumably --download-hdf5 should work with gnu compilers - if it doesn't
>> - it
>> probably needs some tweaking.
>> Wrt repo - we now have a single git repo bitbucket.org/petsc/petsc
>> where all petsc/buildsystem changes should go to.
>> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131004/e56ef8e2/attachment.html>
