[petsc-dev] viewing factored matrices
Jed Brown
jedbrown at mcs.anl.gov
Sat Nov 23 14:06:36 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> XXSetFromOptions() should never be called where it actually cannot
> do anything (besides checking lots of strings) because it has
> already been called on the same configuration. And since the
> options database hasn’t changed the options will be set but they
> will be set with the exact same values as before.
Would it be enough to make the options database carry a version number
that was incremented on changes, cached by each object so that they can
quickly short-circuit? It feels a bit dirty, but would be an easy way
to cut out that processing. Or it could just be used to audit whether
options were being checked redundantly.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131123/6eaeb01d/attachment.sig>
