[petsc-dev] viewing factored matrices
Fri Nov 22 18:59:48 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Sure, but so what? The setfromoptions has to be recalled on all the
>    levels anyways and relative to setting up the GAMG the calls to the
>    setfromoptions is not an issue.
Fair enough.  GAMG is always expensive enough that it's okay to run
through the SetFromOptions on each setup.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131122/68af19bb/attachment.sig>
