[petsc-dev] nightly builds progress
    Barry Smith
    bsmith at mcs.anl.gov
    Sun Nov 17 21:33:09 CST 2013
On Nov 17, 2013, at 9:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> If you look right now - you'll see the logs for 'master' asell.
> The issues is - the builds are scheduled as follows:
> start the 'next' builds at midnight
> collect the logs at 9am
> <update nightlylogs/index.html>
> start the master builds at noon
> collect the logs at 9pm
  It is ok to have some run at night and the others during the day. But they cannot overwrite each others output. You need to set it up so that they go in different places (even same directory is ok with different names) but generate TWO dashboards. One for next and one for master, and both always available. So if I go to the bottom of the petsc-developers page there should always be two links to nightly builds one to master and one to next.
   Thanks
   Barry
> So if we wish to look at the 'master' logs during the regular daytime
> hours we usually have to look at previous day logs.
> Satish
> On Sun, 17 Nov 2013, Barry Smith wrote:
>>  Ok, http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/11/17/ has nightly builds of next. Where are master?
>>   We need to have both sets run daily and a dashboard for each of them set up.
>>    Thanks
>>     Barry
