[petsc-dev] not finding --downloaded Generator for snes ex31
Geoffrey Irving
irving at naml.us
Fri Nov 15 16:48:59 CST 2013
On Fri, Nov 15, 2013 at 12:46 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 15, 2013 at 2:14 PM, Geoffrey Irving <irving at naml.us> wrote:
>> I'm trying to run some of the other FE examples, and am hitting the
>> following error. As configure.log shows, --download-generator
>> succeeded. Should I need a pythonpath tweak to get this to work?
> ex31 is broken (I hope to fix it sometime, but that may be a pipe dream since
> Dave May's code supersede's it). So is ex72. Generator is not needed since
> we added PetscFE, although I could still imagine using some of it to generate
> OpenCL kernels.
Great, thanks. I was a bit confused when I discovered the apparent
quadrature related code generation.
Geoffrey
