[petsc-dev] meaning of NUM_FIELDS in PetscFEM
Jed Brown
jedbrown at mcs.anl.gov
Fri Nov 15 14:28:05 CST 2013
Geoffrey Irving <irving at naml.us> writes:
> To make sure I understand the code correctly: a single field can be
> vector-valued, right? I.e., the position field for elasticity can be
> 1 field, corresponding to NUM_FIELDS = 1 in the various examples?
Yeah, each field can have a number of "components".
> And in ex62, the two fields are pressure and velocity, the latter
> vector valued?
Yup.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131115/96fb4628/attachment.sig>
