[petsc-dev] best fix for -hosts localhost issue
Fri Nov 15 14:02:17 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> ~/Src/newmodel  master $ more /etc/hosts
> # Host Database
> # localhost is used to configure the loopback interface
> # when the system is booting.  Do not change this entry.
> 127.0.0.1       localhost
> 255.255.255.255 broadcasthost
> ::1             localhost
> fe80::1%lo0     localhost
> but note that Apple Mac OS doesn’t (supposedly) use this file except
> at startup
really?
> and somehow sets the hostname based on the network or lack of it.
Is the hostname in /etc/hostname?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131115/079d291f/attachment.sig>
