[petsc-dev] best fix for -hosts localhost issue
Barry Smith
bsmith at mcs.anl.gov
Fri Nov 15 13:46:21 CST 2013
On Nov 15, 2013, at 1:42 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>> No, it is any mpiexec from my laptop when it is not connected to Wifi. It hangs for the timeout
>>> when mpiexec does gethostbyname(), and then runs. Its horrible.
>> Not for me. It runs fine when I am not on a wifi network.
> Barry, what is in your /etc/hosts?
> Matt does *not* have his hostname listed there under 127.0.0.1 because
> he said it caused "some problem”.
~/Src/newmodel master $ more /etc/hosts
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting. Do not change this entry.
127.0.0.1 localhost
255.255.255.255 broadcasthost
::1 localhost
fe80::1%lo0 localhost
but note that Apple Mac OS doesn’t (supposedly) use this file except at startup and somehow sets the hostname based on the network or lack of it.
Barry
