[petsc-dev] best fix for -hosts localhost issue
Fri Nov 15 13:11:12 CST 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>   I always run on my mac and never set a hosts or anything like
>   that. What is the problem? Please send all output from failure if
>   you do not use hosts and configure.log
Matt is the one claiming to need these options, and it's only for
running tests with builder.py.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131115/405c0a7f/attachment.sig>
