[petsc-dev] best fix for -hosts localhost issue
    Barry Smith
    bsmith at mcs.anl.gov
    Fri Nov 15 13:07:16 CST 2013
  I always run on my mac and never set a hosts or anything like that. What is the problem? Please send all output from failure if you do not use hosts and configure.log
   Barry
On Nov 15, 2013, at 12:53 PM, Geoffrey Irving <irving at naml.us> wrote:
> I'd like to implement the right fix for the -hosts localhost issue.
> Recall that the problem is passing "-hosts localhost" to mpiexec when
> running tests.  Matt apparently needs it for his machine (Mac OS X),
> and it is not allowed on mine (Ubuntu, OpenMPI).  Should we check for
> the validity of -hosts and use it if so, or do we like Jed's grumpy
> anti-Mac solution? :)
> Geoffrey
