[petsc-dev] PETSc developers who use weird MPI
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Nov  8 20:44:36 CST 2013
Peter Brune <prbrune at gmail.com> writes:
> Merged into master:
> https://bitbucket.org/petsc/petsc/commits/d27186240524b7073c7cded90e339bd6b28bd6e6
Yes, but you didn't fix the history the way I suggested so we still have
multiple commits that do the same thing.  Not a serious problem, but we
should strive to avoid this sort of clutter, and in this case, it was
easily avoidable.
>> >> This looks possible.
>> >> *   5c44807 (prbrune/mat-matcolor) Merge branch 'prbrune/sf-sfbasicops'
>> into prbrune/mat-matcolor
>> >> | *   8e99f7e (prbrune/sf-sfbasicops) Merge branch
>> 'prbrune/sf-sfbasicops' of bitbucket.org:petsc/petsc into
>> >> | | * f3fe83a mpiuni: change types to use unique IDs [for sf]
>> >> | | * 13d1d6f mpiuni: add MPI_OP definitions required for sfbasic
>> >> | * | a49f225 Added several additional MPI_Ops to PetscSFBasic.
>> >> * | 3142415 Fix for multiple definitions in mat/color/interface/ custom
>> fortran bindings
>> >> $ diff -u  <(git show --format=fuller 53deab3) <(git show
>> --format=fuller a49f225)
>> >> --- /dev/fd/63  2013-11-02 13:40:30.964494674 -0600
>> >> +++ /dev/fd/62  2013-11-02 13:40:30.964494674 -0600
>> >> @@ -1,8 +1,8 @@
>> >> -commit 53deab39b05c95f82ded0f9b5ed98e1eca77ec57
>> >> +commit a49f225f21e5e022456a96fbd0a3a873045b2c5d
>> >>  Author:     Peter Brune <brune at mcs.anl.gov>
>> >>  AuthorDate: Wed Oct 9 14:54:51 2013 -0500
>> >>  Commit:     Peter Brune <brune at mcs.anl.gov>
>> >> -CommitDate: Wed Oct 9 14:54:51 2013 -0500
>> >> +CommitDate: Thu Oct 17 13:38:04 2013 -0500
Specifically, both versions of the commit above are now in 'master'.
>> >> $ git branch -r --contains a49f225
>> >>   origin/prbrune/mat-matcolor
>> >>   origin/prbrune/sf-sfbasicops
>> >> Peter's rebased commit is a49f225, but it does exactly the same thing as
>> >> the original (53deab3) and the only other branch it has been used by is
>> >> 'prbrune/mat-matcolor', so it should be okay to:
>> >> $ git checkout prbrune/sf-sfbasicops
>> >> $ git reset --hard f3fe83a        # gets rid of rebased version and
>> merge
>> >> $ git checkout prbrune/mat-matcolor
>> >> $ git reset --hard HEAD^          # moves back to 3142415
>> >> $ git merge prbrune/sf-sfbasicops
>> >> Test that the above works, then force-push those two branches.
>> >> $ git push origin +prbrune/sf-sfbasicops +prbrune/mat-matcolor
>> > barry/saws is now in master. This brought in prbrune/mat-matcolor
>> > snapshot prior to the mpiuni fix into master.
>> > How do we proceed here? [to get mpiuni fixes into master aswell]?
>> > [i.e Peter do the above cleanup and merge to master - or merge to master
>> as is?]
>> I would say Peter should do the above steps.  Or if he gives his okay,
>> you or I can do it.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131108/9ecac41d/attachment.sig>
