[petsc-dev] PETSc developers who use weird MPI
    Peter Brune
    prbrune at gmail.com
    Fri Nov  8 16:12:23 CST 2013
Merged into master:
https://bitbucket.org/petsc/petsc/commits/d27186240524b7073c7cded90e339bd6b28bd6e6
- Peter
On Fri, Nov 8, 2013 at 2:04 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >> > Should 'prbrune/sf-sfbasicops' and 'prbrune/mat-matcolor' be cleaned
> >> > up to remove the merge between the 'rebased' and 'non-rebased'
> >> > variants of the branches - before the changes got into master?
> >> This looks possible.
> >> *   5c44807 (prbrune/mat-matcolor) Merge branch 'prbrune/sf-sfbasicops'
> into prbrune/mat-matcolor
> >> | *   8e99f7e (prbrune/sf-sfbasicops) Merge branch
> 'prbrune/sf-sfbasicops' of bitbucket.org:petsc/petsc into
> >> | | * f3fe83a mpiuni: change types to use unique IDs [for sf]
> >> | | * 13d1d6f mpiuni: add MPI_OP definitions required for sfbasic
> >> | * | a49f225 Added several additional MPI_Ops to PetscSFBasic.
> >> * | 3142415 Fix for multiple definitions in mat/color/interface/ custom
> fortran bindings
> >> $ diff -u  <(git show --format=fuller 53deab3) <(git show
> --format=fuller a49f225)
> >> --- /dev/fd/63  2013-11-02 13:40:30.964494674 -0600
> >> +++ /dev/fd/62  2013-11-02 13:40:30.964494674 -0600
> >> @@ -1,8 +1,8 @@
> >> -commit 53deab39b05c95f82ded0f9b5ed98e1eca77ec57
> >> +commit a49f225f21e5e022456a96fbd0a3a873045b2c5d
> >>  Author:     Peter Brune <brune at mcs.anl.gov>
> >>  AuthorDate: Wed Oct 9 14:54:51 2013 -0500
> >>  Commit:     Peter Brune <brune at mcs.anl.gov>
> >> -CommitDate: Wed Oct 9 14:54:51 2013 -0500
> >> +CommitDate: Thu Oct 17 13:38:04 2013 -0500
> >> $ git branch -r --contains a49f225
> >>   origin/prbrune/mat-matcolor
> >>   origin/prbrune/sf-sfbasicops
> >> Peter's rebased commit is a49f225, but it does exactly the same thing as
> >> the original (53deab3) and the only other branch it has been used by is
> >> 'prbrune/mat-matcolor', so it should be okay to:
> >> $ git checkout prbrune/sf-sfbasicops
> >> $ git reset --hard f3fe83a        # gets rid of rebased version and
> merge
> >> $ git checkout prbrune/mat-matcolor
> >> $ git reset --hard HEAD^          # moves back to 3142415
> >> $ git merge prbrune/sf-sfbasicops
> >> Test that the above works, then force-push those two branches.
> >> $ git push origin +prbrune/sf-sfbasicops +prbrune/mat-matcolor
> > barry/saws is now in master. This brought in prbrune/mat-matcolor
> > snapshot prior to the mpiuni fix into master.
> > How do we proceed here? [to get mpiuni fixes into master aswell]?
> > [i.e Peter do the above cleanup and merge to master - or merge to master
> as is?]
> I would say Peter should do the above steps.  Or if he gives his okay,
> you or I can do it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131108/8bc59f4b/attachment.html>
