[petsc-dev] make all PETSc Fortran examples modern freeform?
Jed Brown
jedbrown at mcs.anl.gov
Thu Nov 7 11:59:17 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> BTW: if none of the options are specified - compilers usually default
> to 'fixed form' for .f/.F and free form for .f90/.F90.
> So perhaps 'FFLAGS=-fixed-form' will conflict with our .F90 examples -
> so some extra check [to not run .F90 examples] might be needed
> somehwere..
Surely we don't need to make *.F90 examples work with -ffixed-form.
Some of the *.F examples may need updating for -ffree-form, unless some
compiler prefers free-form for *.F.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131107/21b619a3/attachment.sig>
