[petsc-dev] make all PETSc Fortran examples modern freeform?
Thu Nov 7 11:54:54 CST 2013
On Thu, 7 Nov 2013, Satish Balay wrote:
> On Thu, 7 Nov 2013, Barry Smith wrote:
> >    Rather than making a massive change to PETSc, how about the following modest proposal
> >     Add a configure option that causes PETSc to compile Fortran code with the free-form option. When built with this option, of course, possibly many of the current examples just won’t be built in that configuration.
> It already works this way - doesn't it?
> All petsc sources and all .F examples fixed/free-form complaint.
> So if one were to use FFLAGS=-fixed-form or FFLAGS=-free-form things
> should work?
> Perhaps some examples got broke - and they need fixing?
BTW: if none of the options are specified - compilers usually default
to 'fixed form' for .f/.F and free form for .f90/.F90.
So perhaps 'FFLAGS=-fixed-form' will conflict with our .F90 examples -
so some extra check [to not run .F90 examples] might be needed
somehwere..
Satish
