[petsc-dev] openmp
Svetlana Tkachenko svetlana.tkachenko at fastmail.fm
Wed Nov 6 20:19:47 CST 2013
On Thu, 7 Nov 2013, at 12:34, Jed Brown wrote:
> Svetlana Tkachenko <svetlana.tkachenko at fastmail.fm> writes:
> >> > Right. I have spent half of an hour now trying to imagine what to do
> >> > to link trying everything like a headless chicken and it did not
> >> > work.
> >> You always have to send the error message.
> >> > I would appreciate if you could come up with something that links, not
> >> > just runs a single program.
> >> The makefiles we suggested link a program of the same name as the source
> >> file.  Do you have multiple source files?  You only have to edit the one
> >> line and run "make".
> >> program: several.o object.o files.o
> >> 	${CLINKER} -o $@ $^ ${PETSC_LIB}
> >> include ${PETSC_DIR}/conf/variables
> >> include ${PETSC_DIR}/conf/rules
> >> Email had 1 attachment:
> >> + Attachment2
> >>   1k (application/pgp-signature)
> > ~/dev/test/petsc $ cat makefile
> > myexample: myexample.o solver.o
> > ~/dev/test/petsc $ cat solver.f
> >           subroutine solver()
> > #include <finclude/petscsys.h>
> Name your source file solver.F so that the Fortran compiler preprocesses
> it.  (Or add the option -cpp, but that is more confusing and less
> portable, so rename the source file.)
> + Attachment2
~/dev/test/petsc $ mv solver.f solver.F
~/dev/test/petsc $ make
gfortran -c  -fPIC -Wall -Wno-unused-variable -g  -fopenmp  -I/home/<username>/petsc/include -I/home/<username>/petsc/linux-amd64/include -I/home/<username>/petsc/include/mpiuni    -o solver.o solver.F
solver.F:8.46:
              if (ierr .ne. 0) call MPI_Abort(PETSC_COMM_WORLD,ierr,ierr
                                              1
Error: Missing ')' in statement at or before (1)
solver.F:8.72:
        1
Warning: Line truncated at (1)
solver.F:13.46:
                                              1
solver.F:13.72:
        1
make: [solver.o] Error 1 (ignored)
gcc -fopenmp -fopenmp   -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline -O0 -fopenmp  -o myexample myexample.o solver.o -Wl,-rpath,/home/<username>/petsc/linux-amd64/lib -L/home/<username>/petsc/linux-amd64/lib  -lpetsc -Wl,-rpath,/home/<username>/petsc/linux-amd64/lib -lflapack -lfblas -lX11 -lpthread -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -L/usr/lib/gcc/x86_64-redhat-linux/4.4.7 -lgfortran -lm -lm -lstdc++ -lstdc++ -ldl -lgcc_s -ldl
gcc: solver.o: No such file or directory
make: *** [myexample] Error 1
~/dev/test/petsc $
