[petsc-dev] pushing to next fails
Tue Nov 5 17:05:43 CST 2013
Stefano Zampini <s.zampini at cineca.it> writes:
> I removed the trailing whitespaces
> https://bitbucket.org/petsc/petsc/commits/5dd13310d584c8104eddeeabd0df18eb55b5a3f9?at=stefano_zampini/pcbddc-reusebddc
> and added the precommit hook, but still I get the same error from git push.
Merged here:
https://bitbucket.org/petsc/petsc/commits/ceced0834fb9f4d527f3ac0b52dd2430f5110bf0
> I cannot understand where my code is not conforming since the pre-receive
> hook is not verbosed enough.
The code is okay now.
> I read your comments and replied. See also
> https://bitbucket.org/petsc/petsc/commits/165b64e2ecb4f5abc326a9d4c71cd3217b80ea8d?at=stefano_zampini/pcbddc-reusebddc
Thanks.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131105/65731251/attachment.sig>
