[petsc-dev] pushing to next fails
    Stefano Zampini
    s.zampini at cineca.it
    Tue Nov  5 10:37:48 CST 2013
HI,
I'm having troubles while pushing to next. On my working copy, I only
merged stefano_zampini/pcbddc-reusebddc
stefano at MFL:~/Sviluppo/petsc$ git log -2
commit 66e6a3af0fe0b32e7cf482d2fbb030f210ef0827
Merge: d634d3a c1c8e73
Author: Stefano Zampini <stefano.zampini at gmail.com>
Date:   Tue Nov 5 17:06:02 2013 +0100
    Merge branch 'stefano_zampini/pcbddc-reusebddc' into next
commit d634d3a89eac3bdab8f423be26d45c60813fe9c4
Merge: 0fd99ec efe766f
Author: Matthew G. Knepley <knepley at gmail.com>
Date:   Mon Nov 4 16:31:33 2013 -0600
    Merge branch 'knepley/fix-fem-opencl' into next
    * knepley/fix-fem-opencl:
      DMPlex: Fixed flop calculation for OpenCL evaluator - The old version
had (2+2)*dim*N_comp, but I think this should only be 2*dim, which is a 5%
effect
then, when pushing, I got this
stefano at MFL:~/Sviluppo/petsc$ git push -v --set-upstream origin next
Pushing to git at bitbucket.org:petsc/petsc.git
Counting objects: 22, done.
Delta compression using up to 2 threads.
Compressing objects: 100% (8/8), done.
Writing objects: 100% (8/8), 791 bytes, done.
Total 8 (delta 6), reused 0 (delta 0)
remote: permission denied to update branch next
To git at bitbucket.org:petsc/petsc.git
 ! [remote rejected] next -> next (pre-receive hook declined)
error: failed to push some refs to 'git at bitbucket.org:petsc/petsc.git'
Am I doing something wrong?
Ph. D. Stefano Zampini
CINECA
SuperComputing Applications and Innovations Department - SCAI
Via dei Tizii, 6 00185 Roma - ITALY
Email: s.zampini at cineca.it
SkypeID: stefano.zampini
GoogleTalk: stefano.zampini at gmail.com
Tel: +39 06.44486.707
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131105/14b12c0c/attachment.html>
