[petsc-dev] Running dsymutil in GNU make build
Jed Brown
jedbrown at mcs.anl.gov
Mon Nov 4 13:31:15 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
>> If so, we can specify them using pattern rules:
>> %.dll %.dll.a : prereqs
>> recipe
> I think libpetsc.dll, libpetsc.dll.a should work [eventhough the
> convention is not to use 'lib' prefix as libpetsc.dll]
We could rename on install?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131104/6387a620/attachment.sig>
