[petsc-dev] Running dsymutil in GNU make build
Jed Brown
jedbrown at mcs.anl.gov
Mon Nov 4 10:08:41 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> BTW: the 'shared' target from gmakefile is not protable. [It expects
> all compilers to support '-shared' option]. How do we fix this?
In conf/rules, why does shared_linux use CLINKER while shared_darwin
uses LD_SHARED?
One fix is to include the -shared or -dynamiclib in the macro that goes
into petscvariables.
How does current gmakefile work on Macs now? Is -dynamiclib
interchangeable with -shared?
Do we still need special rules for FreeBSD and Solaris? FreeBSD uses
Clang/LLVM now (it GCC before) and the Solaris compilers support -shared
(though the man page only documents -G).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131104/ddfb4e53/attachment.sig>
