[petsc-dev] Running dsymutil in GNU make build
Lisandro Dalcin dalcinl at gmail.com
Mon Nov 4 08:02:29 CST 2013
On 4 November 2013 16:44, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Lisandro Dalcin <dalcinl at gmail.com> writes:
>> Do you like moving the execution of dsymutil from
>> $PETSC_DIR/conf/rules to $PETSC_DIR/gmakefile shared lib targets? The
>> rationale is to not run dsymutil with the shared libs are up to date.
>> diff --git a/conf/rules b/conf/rules
>> index 1ac6fe0..6bf2421 100644
>> --- a/conf/rules
>> +++ b/conf/rules
>> @@ -105,9 +105,6 @@ gnumake: chk_makej
>>         @echo "Building PETSc using GNU Make with ${MAKE_NP} build threads"
>>         @echo "=========================================="
>>         @cd ${PETSC_DIR} && ${OMAKE_PRINTDIR} -f gmakefile -j ${MAKE_NP} V=${V}
>> -       @if [ "${BUILDSHAREDLIB}" = "yes" -a "${DSYMUTIL}" != "true" ]; then \
>> -        echo "Running ${DSYMUTIL} on ${SHLIBS}";\
>> -        for LIBNAME in ${SHLIBS}; do ${DSYMUTIL}
>> ${INSTALL_LIB_DIR}/$$LIBNAME.${SL_LINKER_SUFFIX}; done; fi
> Looks like you pasted into gmail, ruining the formatting.
My intention was to show what I was talking about, not to submit a
patch. It does not render so bad in my gmail.
>  I like
> running it per library rather than as a separate step.
OK, I'll push this change to master.
PS: Do you have any intention to continue supporting CMake builds? We
could do something similar for this case.
Lisandro Dalcin
CIMEC (UNL/CONICET)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1016)
Tel/Fax: +54-342-4511169
