[petsc-dev] PETSc developers who use weird MPI
Peter Brune
prbrune at gmail.com
Sat Nov 2 14:44:13 CDT 2013
On Sat, Nov 2, 2013 at 2:34 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Fri, 1 Nov 2013, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > > On Fri, 1 Nov 2013, Satish Balay wrote:
> > >> > The reason I had to merge all that stuff into saws was that saws
> > >> > could not merge into next because those branches so changed
> > >> > next. I had to merge them into saws before I could get saws into
> > >> > next.
> > Peter forgot what had been released to 'next' and rebased after merging,
> > leading to two copies of the earlier commits. I think that is the
> > reason for much of this confusion.
> Should 'prbrune/sf-sfbasicops' and 'prbrune/mat-matcolor' be cleaned
> up to remove the merge between the 'rebased' and 'non-rebased'
> variants of the branches - before the changes got into master?
Jed mistakes prbrune/sf-sfbasicops with prbrune/snes-qnscaling, which was
unrelated and my bad. It came to the fore because it made clearing up
someone merging next into a branch even nastier. I'm pretty sure that I
didn't rebase sf-sfbasicops or mat-matcolor after merging them to next, so
these things shouldn't exist.
The issue is that prbrune/mat-matcolor didn't get your update to
prbrune/sf-sfbasicops, and Barry merged the prior without the updated
latter. I had merged prbrune/sf-sfbasicops into prbrune/mat-matcolor
because I wrote it *specifically* so that I could do things in
prbrune/mat-matcolor. I had not realized that Satish had updated it and
did not remerge, so barry got the old copy when merging mat-matcolor in.
- Peter
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131102/d00fea11/attachment.html>
