[petsc-dev] PETSc developers who use weird MPI
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Nov  1 22:57:55 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> On Fri, 1 Nov 2013, Satish Balay wrote:
>> >    The reason I had to merge all that stuff into saws was that saws
>> >    could not merge into next because those branches so changed
>> >    next. I had to merge them into saws before I could get saws into
>> >    next.
Peter forgot what had been released to 'next' and rebased after merging,
leading to two copies of the earlier commits.  I think that is the
reason for much of this confusion.
>> >    But I missed 1/2 a one (somehow) getting an outdated verson of
>> >    the sf-sfbasics into saws.
>> No the more appropriate thing here would be to merge/rebase to latest
>> master.
>> And then attempt to merge saws to next.
> $ git log --oneline
> f3d19ed fix outdated PetscOptionsList
> d548240 Merge branch 'prbrune/mat-matcolor' into barry/saws
> 3142415 Fix for multiple definitions in mat/color/interface/ custom fortran bindings
> 76422c6 manually remove old AMS code that got sucked in from master
> fcaff9f Merge branch 'jed/check-pointer-runtime' into barry/saws
> 1a1c1e0 partial update of SAWs with master
> 7737a22 Merge branch 'master' into barry/saws
> I see you have merged master into barry/saws
Why this merge "from upstream"?
> - and then had to merge jed/check-pointer-runtime and
> I'm not sure what can be done here. [my instinct is to reset 'saws' to
> either 7737a22 or the state before that - and redo the 'merge to
> master', and then 'rebase -i' the other required commits - or just
> rebase master onto barry/saws].
I haven't followed the sequence of events (in transit to airport, now
boarded).  What has gone wrong now?
Whatever you do, please don't rebase 'barry/saws' now, since it has been
merged to 'next'.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131101/868d9e8c/attachment.sig>
