[petsc-dev] MatGetBlockSize[s]() before prellocation
    Lisandro Dalcin
    dalcinl at gmail.com
    Fri Nov  1 10:51:23 CDT 2013
Currently, MatGetBlockSize[s]() fails before matrix preallocation
because of the check MatCheckPreallocated(mat,1). Are there any
objections to remove that check?
The rationale is to follow MatGet[Local]Size(), these calls do not
fail before preallocation, why should MatGetBlockSize[s]()?. In
petsc4py, I do need to query the block sizes before preallocation to
do sanity checks on the arrays users pass for preallocating the
matrix.
Lisandro Dalcin
CIMEC (UNL/CONICET)
Predio CONICET-Santa Fe
Colectora RN 168 Km 472, Paraje El Pozo
3000 Santa Fe, Argentina
Tel: +54-342-4511594 (ext 1016)
Tel/Fax: +54-342-4511169
