[petsc-dev] Some questions about adding default global to local, etc., functions for DMShell
    Matthew Knepley
    knepley at gmail.com
    Wed Mar  6 14:18:33 CST 2013
On Wed, Mar 6, 2013 at 2:54 PM, Richard Tran Mills <rtm at eecs.utk.edu> wrote:
>  Hi Folks,
> I am adding some pointers to scatter contexts within the internal "data"
> struct for DMShell, e.g. the 'gtol' and 'ltog' members in
> typedef struct  {
>   Vec Xglobal;
>   Vec Xlocal;
>   Mat A;
>   VecScatter *gtol;
>   VecScatter *ltog;
> } DM_Shell;
> First question: When in DMCreate_Shell we do
> ierr     = PetscNewLog(dm,DM_Shell,&shell);CHKERRQ(ierr);
> will this guarantee that gtol and ltog are set to NULL, or do I need to
> explicitly set these somewhere?  I see that the allocated memory is zeroed
> but I'm not sure how NULL might actually be represented in memory.
Yes, they will be NULL.
> I have also added some new functions like
> DMShellDefaultGlobalToLocalBegin()/End(), and in DMCreate_Shell I do
>   dm->ops->globaltolocalbegin = DMShellDefaultGlobalToLocalBegin;
>   dm->ops->globaltolocalend   = DMShellDefaultGlobalToLocalEnd;
> The user can set different routines via
> DMShellSetGlobalToLocalBegin()/End(), but if the user only sets the gtol
> and ltog scatter contexts, then the default routines will perform the
> appropriate scatter operations.
> Second question: What is the proper "PETSc way" to throw an error if gtol
> is NULL and tell the user that DMShellDefaultGlobalToLocalBegin() cannot be
> used without first setting the scatter context via
> DMShellSetGlobalToLocalVecScatter()?
SETERRQ(comm, PETSC_ERR_ARG_WRONGSTATE, "DMShellDefaultGlobalToLocalBegin()
cannot be used without first setting the scatter context via
DMShellSetGlobalToLocalVecScatter()");
   Matt
> Thanks,
> Richard
> Richard Tran Mills, Ph.D.
> Computational Earth Scientist      | Joint Assistant Professor
> Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
> Oak Ridge National Laboratory      | University of Tennessee, Knoxville
> E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130306/32951c50/attachment.html>
