[petsc-dev] Ongoing formatting changes
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Jan 28 16:25:33 CST 2013
On Mon, Jan 28, 2013 at 4:21 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> I don't expect Doxygen-only either for the next release, there's still too
> much Fortran-stuff attached to sowing. Running a Doxygen site in parallel
> is an option iff Doxygen is the way to go in the long run. Otherwise, this
> will only screw up search engine results and finally create dead links over
> time and should thus be avoided...
Well, you can still link it as experimental and turn off indexing so it
doesn't show up in search results. (I'm not prepared to commit to it yet; I
still want to experiment with a couple other options.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130128/2a42deaa/attachment.html>
