[petsc-dev] Nightly tests quick summary page
Karl Rupp
rupp at mcs.anl.gov
Thu Jan 24 09:39:48 CST 2013
Hi Jed,
> It's also a matter of the need for a 'yes/no'-testing. Running a
> fixed test like
> if (err > eps) fail_test();
> is probably too harsh and we instead use some kind of continuous
> metric to judge the outcome of the test.
> Agreed, but note that an arbitrarily small continuum difference can
> force an additional iteration. Maybe our tests should be configured to
> "always run exactly 10 iterations". I wonder if a Bayesian filter could
> be trained to recognize real failures.
Testing for the same number of iterations is - as you mentioned - a
terrible metric. I see this regularly on GPUs, where rounding modes
differ slightly from CPUs. Running a fixed (low) number of iterations is
certainly the better choice here, provided that the systems we use for
the tests are neither too ill-conditioned nor too well-behaved so that
we can eventually reuse the tests for some preconditioners.
> Speaking of a HTML table, something that is spinning in my head for
> a long time already is that one can easily draw diagrams
> automatically showing the convergence history of the residual norm
> obtained in a test run. Coloring the frame of the plot proportional
> to the relative deviation from a reference convergence history gives
> you a quick idea of how far a test is off the reference. It won't
> work for all tests, but it gives you on idea about the sanity of the
> implementation.
> I spend years trying to convince people to use actual norms instead of
> jpeg semi-norms and now you want to reverse that? Blasphemy!
Haha :-D Did I just throw the first stone? ;-)
> Actually, that's an interesting idea. I guess it could be presented in a
> more compressed way than the numerical values, thus providing a better
> summary.
Yep. Actual norms should still be used for collecting 'hard facts' about
the state, and a 'pretty picture layer' will drive up efficiency in
interpreting the results.
Best regards,
Karli
