[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Karl Rupp
rupp at mcs.anl.gov
Tue Jan 22 15:46:22 CST 2013
Hey,
> A user that is just experimenting with an example will not set up
> the pre-commit hook anyway. I still rely on developers adding the
> pre-commit hook by themselves rather than magically interfering with
> hgrc. The latter would be borderline evil, yes.
> Okay, note the original context:
> >> Note that pre-commit cannot be run on a user's machine without their
> >> assistance (configuring hgrc). (Doing so would be a huge security
> >> vulnerability.)
> > Yes, I'm aware of that. Since we have to update hgrc for the
> BuildSystem anyway, it's 'just another line'.
> which is why I thought you were going to have configure slam some commit
> hook crap into the user's hgrc (like it sometimes does for BuildSystem
> because we haven't switched to using submodules).
Oh, I wasn't aware that there is some direct slamming at all. My only
reference was the 'please add the line manually'-way described for
petsc-dev:
http://www.mcs.anl.gov/petsc/developers/index.html
> In such case I'm afraid I have no idea about how to ensure
> correct
> formatting other than hoping that users run pre-commit
> checks... :-(
> Education: make them fix their patches (enable those extensions,
> read
> the docs, etc) and resubmit.
> s/users/developers/, sorry.
> I'm less concerned about actual users only contributing patches, but
> about developers with push-permission. Every non-compliant push will
> make subsequent pre-commit checks fail, regardless of whether it's
> the particular developer's fault.
> The way to enforce this is to have the server reject non-conforming
> pushes, or to move to more of a pull model where fewer people can push
> directly and the trusted people can be trusted to have their local hooks
> configured.
Do you know any clean way of rejecting non-conforming code at
server-side? The obvious pre-push hook requiring developers to adjust a
commit does not seem to be an option (the process of doing so might
drive Barry into a berserker).
The pull-model may only delegate the task of fixing a commit to the
trusted developers and require additional work. so, instead of a fixing
commit, we may start exchange patches (again).
I'm afraid that there's not going to be a clean solution to protecting
the repository. Keeping a couple of style checkers and fixing violations
once in a while seems to be the most efficient approach then.
Best regards,
Karli
