[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Jed Brown
jedbrown at mcs.anl.gov
Tue Jan 22 15:16:06 CST 2013
On Tue, Jan 22, 2013 at 3:06 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> A user that is just experimenting with an example will not set up the
> pre-commit hook anyway. I still rely on developers adding the pre-commit
> hook by themselves rather than magically interfering with hgrc. The latter
> would be borderline evil, yes.
Okay, note the original context:
>> Note that pre-commit cannot be run on a user's machine without their
>> assistance (configuring hgrc). (Doing so would be a huge security
>> vulnerability.)
> Yes, I'm aware of that. Since we have to update hgrc for the BuildSystem
anyway, it's 'just another line'.
which is why I thought you were going to have configure slam some commit
hook crap into the user's hgrc (like it sometimes does for BuildSystem
because we haven't switched to using submodules).
> This is horrible because the aggregating commit will touch lots of
>> irrelevant lines. If it does more than change whitespace, git/hg
>> can't
>> even give us a diff that looks past that rearrangement. It's
>> important
>> for every commit making it into the repository to be formatted
>> consistently.
>> In such case I'm afraid I have no idea about how to ensure correct
>> formatting other than hoping that users run pre-commit checks... :-(
>> Education: make them fix their patches (enable those extensions, read
>> the docs, etc) and resubmit.
> s/users/developers/, sorry.
> I'm less concerned about actual users only contributing patches, but about
> developers with push-permission. Every non-compliant push will make
> subsequent pre-commit checks fail, regardless of whether it's the
> particular developer's fault.
The way to enforce this is to have the server reject non-conforming pushes,
or to move to more of a pull model where fewer people can push directly and
the trusted people can be trusted to have their local hooks configured.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130122/6129d0e6/attachment.html>
