[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Tue Jan 22 14:49:51 CST 2013
On Tue, Jan 22, 2013 at 2:42 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi,
> >     Yes, I'm aware of that. Since we have to update hgrc for the
>>     BuildSystem anyway, it's 'just another line'.
>> Yeah, well, I still think it's rude for a build script to mess with the
>> user's private repository configuration. We only get away with it
>> because beginners don't know better and experts usually configure their
>> system so it doesn't run (e.g., by pulling BuildSystem themselves) or
>> know that it's running.
> It may be rude, but it only affects those who consider pushing to
> petsc-dev. Among these few, how many keep a private repository
> configuration? For all others, we ask them to send patches, so we can still
> control the formatting issue.
The context here was a _precommit_ hook. That runs before you've decided
whether you're going to push anywhere. A user that is just experimenting
with an example _should_ commit their work, but in a bookmark/branch that
will never be pushed (though they could send a patch if they were asking
for support). If you write a pre-commit hook into their config, you
interfere with the functioning of their private repository. I consider this
borderline evil.
>>     Eventually we can come up with a hook that aggregates multiple
>>     commits, i.e. the user only needs to add a follow-up commit fixing
>>     the violation rather than fiddling with the history.
>> This is horrible because the aggregating commit will touch lots of
>> irrelevant lines. If it does more than change whitespace, git/hg can't
>> even give us a diff that looks past that rearrangement. It's important
>> for every commit making it into the repository to be formatted
>> consistently.
> In such case I'm afraid I have no idea about how to ensure correct
> formatting other than hoping that users run pre-commit checks... :-(
Education: make them fix their patches (enable those extensions, read the
docs, etc) and resubmit.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130122/790851af/attachment.html>
