[petsc-dev] Style Guide: How to format single-line	if/for/while-blocks?
    Karl Rupp
    rupp at mcs.anl.gov
    Tue Jan 22 11:21:45 CST 2013
 >>>>>     Unfortunately the CPP crap in PETSc messes things up a bit,
curse that CPP wish we could eliminate it all. And yes CPP is C
preprocessor not C++.
>>>> Does it? For the formatting itself it's just another layer…
>>>    Yes but it doesn't fit into the C AST.
>> If I'm not mistaken, one can attach a preprocessor to a compiler object and generate some kind of syntax tree as well as a full C AST. This allows some additional back-and-forth operations.
>     There is the theory, and then there is the practice :-(
I couldn't find a good way of dealing with the CPP inside Clang without
getting a lot of headache and ending up interfering with the lexer and
all the low-level stuff. So, that rabbit hole is A LOT bigger when it
comes to practice in coding style...
So, so I will continue quickly along the following path:
  -> Bring sources to a clean state
  -> Provide simple and robust guard scripts (pre-commit/pre-push)
  -> Configure uncrustify such that it reports violations (nightly)
  -> Document user-specific uncrustify configs
I don't want to leave things in the current half-done state, this would
have been a complete waste of time then.
Best regards,
Karli
