[petsc-dev] Style Guide: How to format single-line if/for/while-blocks?
Karl Rupp rupp at mcs.anl.gov
Mon Jan 21 19:23:55 CST 2013
>               Things like
>               if (y < 12) {ierr = Something(); CHKERRQ(ierr);}
>         don't match the standard but …. am I being too picky? I believe
>         the PETSc make uncrustify rule would move that to separate lines.
>     I expect that it's a lot easier to define a rule where '{' opens a
>     new block on the next line rather than having a 'sometimes it's a
>     single line'-type of exception.
> Yes, though
> if (y < 12) {
>    ierr = Something();CHKERRQ(ierr);
> takes three times as many lines. I don't care much either way, but it's
> nice to not waste vertical space.
But, unfortunately, it is also a good example of why uncrustify-like
tools have a hard time with PETSc:
  if (y < 12) {
     ierr = Something();
     call_other_function(ierr);
is semantically very much the same to a parser, yet it should lead to
different formatting.
Best regards,
Karli
