[petsc-dev] I hate this one
Mon Jan 21 09:51:58 CST 2013
On Mon, Jan 21, 2013 at 9:42 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Again, the data does not support you. An incredible number of instances,
> and almost all files were changed. Thus,
> this was far from "unconventional".
With a version from last week (before the formatting changes):
$ git grep '^ \+for (' src | wc -l
11387
$ git grep '^ \+for(' src | wc -l
1210
$ git grep '^ \+while (' src | wc -l
926
$ git grep '^ \+while(' src | wc -l
156
$ git grep '^ \+if (' src | wc -l
22760
$ git grep '^ \+if(' src | wc -l
129
Is 10% small enough to be called "unconventional"?
> _You_ are not even entertaining the possibility that small variability in
> source can be tolerated. That is incredibly close minded.
You've said that the only reason you care about this is because it affects
readability, which is exactly the reason to have consistent formatting
guidelines in the first place.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130121/6a171399/attachment.html>
