[petsc-dev] zindx undeclared in ml.c
Fri Jan 18 15:03:02 CST 2013
On Fri, Jan 18, 2013 at 2:57 PM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> I guess not many people are linking with ML because changeset
Not many people linking ML built with Zoltan support, more precisely. This
should fix it.
https://bitbucket.org/petsc/petsc-dev/commits/72c712a320d0dd7fdbc5a4aab6601d2b8638a21e
>     8205eea
> introduced the undeclared the variable 'zindx' in
>     src/ksp/pc/impls/ml/ml.c
> It's on line 1109 in the tip. My compiler bails out when it hits it.
> Garth
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130118/57af7c51/attachment.html>
