[petsc-dev] PETSc goes Doxygen!?
Karl Rupp rupp at mcs.anl.gov
Tue Jan 15 18:34:06 CST 2013
 >     At least for PetscScalar and PetscReal this is unfortunately not the
>     case:
>     include/petscmath.h"
>     #if defined(PETSC_USE_COMPLEX)
>     typedef PetscComplex PetscScalar;
>     #else /* PETSC_USE_COMPLEX */
>     typedef PetscReal PetscScalar;
>     #define MPIU_SCALAR MPIU_REAL
> They really are documented:
> http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscScalar.html
Oh, we use different definitions of 'documented'. I'm referring to
documentation right at the place of declaration/definition.
PetscScalar.html is generated from some comment block at some other spot
in the sources, hence Doxygen fails to associated it with the correct
typedef (this could be resolved by an injection of suitable Doxygen
commands).
Best regards,
Karli
