[petsc-dev] PETSc goes Doxygen!?
Matthew Knepley
knepley at gmail.com
Tue Jan 15 16:47:24 CST 2013
On Tue, Jan 15, 2013 at 4:36 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi Matt,
> Right now, the search stinks. If I type in
>> GetCone
>> I get nothing found, whereas
>> DMPlexGetCone
>> has three things found, but does not find DMPlexSetCone. This is crappy,
>> and will
>> not replace seeing everything on one page, which I miss.
> Well, you can't expect the search engine to find DMPlexSetCone if you
> search for DMPlexGetCone ;-) Either of the two is correctly
> cross-referenced at the other's man page, though.
I would expect this, just as I expect one letter misspellings from Google.
> There is also a server-side driven search engine (off by default), maybe
> that one will also find results for 'GetCone'.
There is a nice modular Apache search engine, but I'm not sure how easy
Doxygen is to modify. This is actually
the root of my anxiety.
Matt
> Regardless, listing all functions of a class for the various levels on one
> page is something I can fairly easily add if we finally decide to keep
> Doxygen.
> Best regards,
> Karli
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130115/287809e5/attachment.html>
